Counter/Timer
DAQmx RTSI Counter
Hello All,
I am attempting to generate a 40kHz counter and export the signal to a RTSI channel in order to synchronize two PCI-NIDAQmx cards(6025 & 6259) for analog output signal generation.   I have made my best effort to create the VI, but am receiving the following error:
"Labview: Internal Error.  Wrong memory zone accessed."
Any assistance would be greatly appreciated, and I'm open to any suggestions or alternate methods!
Sincerely,
Zach
(4,152 Views)
Hi Zach,
I took a look at your code, and I believe I have the answer as to why you are receiving this error. It appears that you created a constant for your Simple Error Handler to specify the "type of dialog", but you accidentally wired it into the top-most input terminal, which is the "error code" input. Thus, since you selected "OK message + warnings" on that enum, it is passing the value of 3 into the error code, and thus returning the error you are seeing every time you run the VI.
In addition, based on your explanation of what you are trying to accomplish overall, I am not sure that your code will do quite what you are expecting. You are using the Export Signal VI to route the Counter Output Event to the RTSI_0 line, but this is not the same as routing the output of the counter. The Counter Output Event is a signal that will pulse when the counter reaches its terminal count during an input task. In your case, you would actually want to connect the counter output line, specified as "Dev1/Ctr0Out" to your RTSI line using the Connect Terminals VI. You will also then have to disconnect these terminals at the end of your program before clearing the task. I went ahead and made the above changes to your VI and have attached it below. Please also note that DAQmx allows you to route signals over the RTSI bus without having to manually connect the terminals to the RTSI line. Therefore, you could specify the source of your sample clock on one device to be the counter output of the other device, and as long as you have properly configured the boards in Measurement & Automation Explorer (MAX) to be used with the RTSI cable, it will automatically route the proper signal over the RTSI bus. Hope this helps with your application,
Daniel S.
(4,132 Views)
