Counter/Timer
Delay generator for laser system
I'm looking into purchasing a new delay generator for a laser setup. The setup includes control through either TTL, 5 V pulses, or < 5 V pulses. I'm not quite familiar with some of the terminology in the specs. I need to be able to have a delay step size of around 50 ps. I've been looking into the PXI-6562, which says it has a delay range of "1/256 of sample clock period for clock frequencies ≥ 25 MHz or 60 ps, whichever is greater". Our laser system has a repetition rate of 10 Hz. Does this mean that we will have a delay range of 60 ps? Is this the same as having a step size of 60 ps?
(7,250 Views)
Hi ryder_2010,
The 6562 doesn't sound like the correct hardware for your application.  It's a digital waveform generator/analyzer which uses LVDS logic levels.
Instead, I think you should be looking at the GFT9404, which is designed specifically as a delay generator and offers 1 ps delay resolution (on 4 channels).  If you have any questions about this module feel free to post back--I actually haven't yet used it myself but I can forward this forum along to somebody who is more familiar with it if necessary.
Best Regards,
John Passiak
(7,243 Views)
I actually did look at the 9404 as well, it just isn't a great fit for our application. I don't need resolution as low as a single ps, and I need something lower than 5 ns. I would also prefer something with at least 12 channels. Is this the only delay generator that is offered by NI, or do I have other options? Also, what signals is LVDS capable of sending?
Thanks for the help.
(7,232 Views)
Hi ryder_2010,
LVDS stands for Low-voltage differential signalling--the logic levels are as follows:
I took the image from here, there is actually a typo in that 1V should correspond to VOL (not VOH).
So, the logic levels don't line up with your requirement.  There are other HSDIO products with data delay that have other logic levels, but nonetheless I really don't think data delay is what you are looking for either (you can read more about it here).  It is typically used to delay generation/acquisition data relative to a sample clock (very useful when testing digital interfaces that require settling time etc.).  You might want to provide a timing diagram to help show what exactly you need and how the various channels fit in--perhaps it might be possible with HSDIO but I'm not terribly optimistic.
It sounds like you are looking for a delay generator like the GFT9404 but with more channels.  Unfortunately, NI does not currently have such a product available.
Best Regards,
John Passiak
(7,224 Views)
Hey ryder,
We have a product that we have just released, the PXIe-6556, which sounds like it may be a compatible fit for your application.  It has data delay and data deskew features which can delay down to 30 ps of resolution per channel, 24 channels and has a voltage range that goes from -2V to 7V.
Take a look at the product and its specifications and let us know if you have any questions.  If you need to contact me directly, send me a private message and we can discuss your application further.  Thank you.
Kyle A.
Senior Applications Engineer
(7,215 Views)
If you wish 1 ns and 12 channels, you may gang 2 BNC 575's, http://www.berkeleynucleonics.com/products/model_575.html, together as a cost-effective alternative.  The resolution is 250 ps.
(7,155 Views)
