Counter/Timer
Digital frequency measurement speed in labview
Czechmarty,
This is an easy one to miss, I actually made this mistake a little less than a week ago before figuring out my problem.  The problem is that you cannot use sample clock timing with a CI Frequency task.  There are 3 solutions to this problem:
  1. Get one of our new X Series Cards that have a sample clock line on each of their 4 counters
  2. Perform a count edges and do a frequency calculation in software (only for low frequencies) like in this example.
  3. Last but certainly not least (the easiest fix) is to switch your timing type from Sample Clock to Implicit this won't allow you to "sync" your counters but I really doubt this is a problem.
Sincerely,
Jason Daming
http://www.ni.com/support
Message 11 of 11
(2,189 Views)
