Counter/Timer
Disturbed signal
Hi i'm trying to read with signal express a 5V ttl signal generated by a function generator, but what i see on the screen is very disturbed signal. Could somebody please tell me why?
pollon
Message 1 of 9
(5,654 Views)
Hello Pollon,
Did you create the signal from LabVIEW and then you tried to read it with Signal Express? Could you post the file?
Regards
Matteo
Message 2 of 9
(5,642 Views)
Hi Matteo, i create the signal with a function generator and i read it with signal express!!!!!
pollon
Message 3 of 9
(5,640 Views)
Pollon,
Thank you for repeat me the same information you posted before Smiley Very Happy, i need the format file you used to save your data and the details of the reading step you created.
Matteo
Message 4 of 9
(5,634 Views)
Hi Matteo, first of all i want to thank you for your help. here are all the ins and outs of my measure.  Hope this will help
Regards
Paul
pollon
Message 5 of 9
(5,628 Views)
Hi Paul,
Thank you for the error documentation, it's very useful. My question is if the first acquisition step give you a corrupted measure or only the formula step returns this triangle wave. Did you try acquire different waveform?
Matteo
Message 6 of 9
(5,606 Views)
Hi, i tried to measure different kind of signals but every time there was a disturbed signal. Anyway it's the first acquistion step thet gives me the disturbed signal. The connection wire may be a problem?
pollon
Message 7 of 9
(5,604 Views)
Hi, i want to specify that the tringle wave is the signal that i want to measure but without all those spikes.
Paul
pollon
Message 8 of 9
(5,599 Views)
Hello Paul,
Of course, the wiring connections procedure could be a critical aspect of the noise generation on your signals. Please refer to this document to check the suitability of your wiring configuration:
https://www.ni.com/en/shop/data-acquisition/measurement-fundamentals/field-wiring-and-noise-consider...
Let me know if these advices are sufficient to solve the problem.
Matteo
Message 9 of 9
(5,586 Views)
