Counter/Timer
ETS Pulse Generation for M-series DAQ
According to the M-series device documentation, the PCI-6221 should be able to generate pulses with a "cumulatively incrementing delay" to aid in implementing an undersampled waveform capture routine. Can I access this feature using NI-DAQmx?
Best Regards,
Frank R.
(3,600 Views)
Hello Frank,
It is actually called auto-increment. To enable auto-increment in DAQmx you would use a DAQmx Channel Property Node to configure the increment to Load Register A.
The property name is Counter Output->General Properties->Auto Increment Counter->More->Auto Increment Counter.
I still have some trouble picturing you specific case to use it. You can undersample at constant rate.
Best Regards to you as well
Yardov
Gerardo O.
RF SW Engineering R&D
(3,587 Views)
