Counter/Timer
Enable Debounce Filter in Signal Express
Hallo everybody,
I want to measure the frequency from a rotary encoder but I the enviroment is electromagnetical noisy. The encoder is near an inverter and as a result the proper measuring of the pulses is inevitable. I use the 6211 usb ni card. From my search in the forums, I discovered that enabling the debouncing filter will solve the problem but I cannot figure out how this can happen in Signal Express.
Any suggestions will be helpful. Thank you.
(5,883 Views)
Hi ipallis,
So the first thing to note is that SignalExpress is not a full scale development environment like LabVIEW. This means that some functions that may be available in LabVIEW will not be available in SignalExpress. Unfortunately I believe this may be the situation you are running into. This article talks about how to enable the debounce filter in LabVIEW: http://digital.ni.com/public.nsf/allkb/220083B08217CFD686257131007E5D2C
Enabling the debounce filter can be done through a property node which is a more advanced function, and likely only available in LabVIEW.
Rachel M.
(5,852 Views)
