Counter/Timer
Error -200077 when creating C0Channel with PCIe-6321
I am currently trying to execute the "GenDigPulseTrain_ContBuff_ExtClk" example.
But whenever I click the start button, the following error message appears:
No matter what value I use for the duty cycle I can't seem to get rid of this error.
I am using a NI PCIe-6321.
Any help appreciated.
(3,827 Views)
Have you tried a value that falls in the range denoted by the error message?  Duty cycle needs to be a fraction not a percentage.  I suspect you've only tried values in the 1-99 range while thinking percentage, 100x too large.  Try fractions in the range 0.01-0.99
-Kevin P
(3,805 Views)
Hi thanks for the reply, I actually already resolved this. The problem was, that the double conversion of the C# example does not take Culture into account. On my system a 0.5 in a textbox converts to 5... while a 0,5 converts to 0.5...
(3,789 Views)
