Counter/Timer
Error -200371 while starting a task containing counter output channels on the same terminal id of different modules on a cDAQ chassis
I have simulated a cDAQ-9178 chassis (cDAQ1) and 2 modules:
1) NI 9402 - cDAQ1Mod1
2) NI 9481 - cDAQ1Mod2
I created a task and add 2 channels to it:
1) ctr0 of cDAQ1Mod1
2) ctr0 of cDAQ1Mod2
If I attempt to start the task, I see the following error message:
Error -200371 occurred at DAQ Assistant
Possible Reason(s):
Requested multiple virtual channels that correspond to the same physical channel within a task. A task cannot contain multiple physical channels of a specified type.
Use different physical channels for each virtual channel.
Channel Name: PulseOutput
Physical Channel: _ctr0
Channel Name: PulseOutput_0
Is there a method you would recommend to generate a pulse train from 2 different cDAQ modules on the ctr0 channel of the individual modules?
Varun Hariharan
MathWorks
(4,604 Views)
Have you tried creating two different tasks? If not, I think that would be our best option. Is there a reason you want to include them in the same task?
(4,576 Views)
I would like to add them to the same task in order to have the channels start together.
Varun Hariharan.
(4,096 Views)
