Counter/Timer
Error -200474 occurred at DAQ Assistant(pci-6602 to scb68)
i had it working on a different PC.  Is there something wrong with the drive or the PC itself?
(5,114 Views)
Accepted by topic author nerd
What is the intended purpose of the DAQ Assistant? Has the device name changed when moving PC? Are you only running the DAQ Assistant?
Glenn
Glenn
(5,098 Views)
Thx, but it was a loose connection to the SCB68 board.  i never touched it, but it was not tightened down and must have got bumped.  so alway check to connections.
(5,094 Views)
