Counter/Timer
Externally controlled counter direction with USB-6211
I am using a USB-6211 and created a simple read counter application with the DAQ Assistant. It counts pulses (1 sample on demand) on Counter 0 (PFI0). When I set Direction to Externally Contolled it does not work properly. It counts random up and down. According to the manual my direction input line is Ctr 0 B (PFI1), but the level of this pin has no effect. What am I doing wrong?
(4,745 Views)
Hello Steffan,
According to the following Knowledge Base you have cannot use the default settings wehn trying to externaly control the direction of the counter:
http://digital.ni.com/public.nsf/allkb/1A8818274130FA388625722E00760CC9?OpenDocument
Since these changes cannot be done in the DAQ assistant you have to use the DAQmx API to resolve this. I have attached a small example that does a simple event count on the source pin of counter 0 (which is also the A input of the counter). With a property node I have set the Counter Direction input terminal to PFI 1 (which is the B input). Now when the PFI 1 is low you will count up, when it is high you will count down.
hope this helps,
RikP - National Instruments Applications Engineering
Message Edited by RikP on 06-05-2008 10:12 AM
Rik Prins, CLA, CLED
Software Development Engineer
(4,722 Views)
Thanks alot, that just solves it! I searched this forum but this KB article didn't cross my search path.
(4,719 Views)
Hi!
I have a similar problem, perhaps with a somewhat different solution.
I am using the NI myDAQ and I need to keep track of a rotating disc, using a counter. The direction of the spin is also important so I would like to use the externally controlled direction counter.
I tried the example attached here, thinking that my problems would be solved.
Unfortionately, this was not the case.
My symptoms using the above example are: The only allowed counter direction is up.
If I change direction to down or external; no difference.
If I stop the GUI and restart it when "Externally" or "Count Down" are chosen Error -200077 is presented
(Possible reason(s):
Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Property: CI.CountEdges.Dir Requested Value: Count Down You Can Select: Count Up
Channel Name: myDAQ1/ctr0
Task Name: _unnamedTask<10>)
Any help to this matter will be much appreciated.
(3,961 Views)
Hello sumosimon,
It is unfortunately not possible to specify the count direction externaly on the NI myDAQ. So, you will not be able to run this example.
Cédric | NI Belgium
(3,919 Views)
