Counter/Timer
FPGA photon counter low voltage
Hi! I'm currently building a photon counter using the USB-7856R R series multi function rio. I have attached the labview program I'm using to count 1VPP square waves, and it works just fine. However, I eventually want to use it for photon counting, and our photon counter only outputs a signal of 200mV, which from what I understand is too low for any of the FPGA logic structures. Am I correct in this, and if so, is there any way to circumvent the issue?
Thank you!
(2,797 Views)
Hi JCard,
You are correct on the digital logic levels. 200mV is too low for digital output.
As I see it, there are two main routes forward (there may well be others).
1. Find a way to increase the voltage (e.g. amplifier)
2. Switch to analog input and count when the voltage exceeds a particular threshold.
Best of luck with the photon counting!
Kevin S.
Technical Support Engineering
(2,755 Views)
