Counter/Timer
GPCTR_Watch porting problem
Hello?
My device is PCI-6025E and GPCTR_Watch function can't be ported to DAQmx clearly as long as I know.
The last parameter of this function is entity value which ranges from 0 to 224 - 1 in E series.
We used this third parameter to count up DMI samples that is feeding PFI3 pin. But there seems no way to count this DMI with any DAQmx code. How can I count this up just like MAX test panel does? The MAX test panel counts from 0 to 224 - 1.
I'm converting DAQ to DAQmx..from Parkoz.com
(5,639 Views)
Hello Anarkie,
It looks like you're looking to perform a count edges task. There is an excellent group of examples in the NI Example Finder that shows how to perform these types of tasks in NI-DAQmx. It would be best to start with the Count Digital Events VI.
Let me know if you have any questions about any of these examples.
Dan King
(5,629 Views)
Ah...I'm looking for Visual C++ solution not VI...
Thanks anyway.
(5,627 Views)
Hello Anarkie,
You can find DAQmx ANSI C examples for the same type of function by going to Start»All Programs»National Instruments»NI-DAQ»Text-Based Code Support»DAQmx ANSI C Examples and then navigating to Counter\Count Digital Events\Cnt Dig Events. This should be what you are looking for to run in a Visual C++ application.
Dan King
(5,625 Views)
Hello?
I know there is a function called DAQmxErrChk (DAQmxReadCounterScalarU32(taskHandle,10.0,&data,NULL)); in that folder.
But I really wonder the data parameter of DAQmxReadCounterScalarU32 is equivalent to the third parameter of GPCTR_Watch function.
Thanks,Robot wink
(5,622 Views)
Hello Anarkie,
The GPCTR_Watch function is defined as follows (from the Traditional NI-DAQ (Legacy)™ C Function Reference Help, Version 7.x😞
"status = GPCTR_Watch (deviceNumber, gpctrNum, entityID, entityValue)"
The third parameter, entityID, is described as the "identification of the feature you want to monitor". The correct correlation of the &data parameter would be the fourth parameter of the Traditional NI-DAQ function, entityValue.
Dan King
(5,602 Views)
