Counter/Timer
Generate Pulse Train.VI replacement for DAQ-STC
I am trying to upgrade an old program (which I did not write) to work with new hardware. The old hardware was AT-MIO-64E-3 which apparently used an AM9513 counter chip. The new hardware is PCI-6071E which apparently uses DAQ-STC. The VI that won't work is Generate Pulse Train.VI, presumably because the correct hardware is no longer available (Error -10041 in CTR Mode Config--The specified TaskID is invalid.) The simple LabVIEW examples using this VI will not work either and generate the same error. What I'm wondering is if there is a drop-in replacement for this VI that will work with the new hardware, or an example of a continuous pulse train generator that will not be hard to substitute for the old VI. I'm sure thi
s cannot be hard and that there's code out there but I'm new to DAQ stuff and have been unable to find an example of this nature. Thanks...
(3,478 Views)
Found what I was looking for. The resulting page upon posting this question had a link to the LabVIEW palette upgrade for new counter VI's.
(3,478 Views)
