Counter/Timer
Generate a train pulse and data acquisition
Hi !!! I am a rookie in the domain but i have got a Ni pci 6602 Card. I'm programming with with Visual C++. With one counter i generate a signal1 with a choosen frequency and with another counter i' m receiving an external signal2. My objective is to count the number of pulses of the signal1 occurred between 2 rising edges of the signal2. I would like some tips PLEASE !!!!
Thank.
(3,883 Views)
See the following links about edge counting they might help you for your problem:
http://zone.ni.com/devzone/conceptd.nsf/webmain/518ca6a920ce63ff86256802007b852e
http://zone.ni.com/devzone/conceptd.nsf/webmain/51113501fbb9b10986256802007b8aa3
These document are mostly related to LabVIEW but it should be working the same way with Visual C++ if you are using the DAQmx API.
Hope this help,
Regards
ClémentG
(3,838 Views)
Also there are good references for C programming with DAQmx contained within the DAQmx driver.  When you install it, there is a C reference help located at Start >> Programs >> National Instruments >> NI-DAQ >> NI-DAQmx C Reference Help.
Some examples are also installed with the driver.  These will be located at C:\Program Files\National Instruments\NI-DAQ\Examples.
Brian B
Account Manager
(3,819 Views)
