Counter/Timer
Generate and measure PWM on cDAQ without any module
So, I can generate a PWM Signal, i.e. 1kHz 50% duty cycle on let's say /cDAQ4/Ctr0InternalOutput.
Can I anyhow measure the frequency and duty cycle of this, without using any module in the cDAQ Chassis? I mean, route this Signal to another internal terminal and create a frequency measurement Task for it.
Any help is appreciated!
(2,811 Views)
could you please elaborate a bit more on what you actually want to achieve, as I'm not fully sure I understand it correctly. Is the PWM signal also generated by same cDAQ? Also, which cDAQ are you using?
Thanks.
CLA,CTD,CLED
(2,763 Views)
