Counter/Timer
Generate pulse frequency with usb-6259 on matlab
I would like to create a pulse with the ni usb-6259 counter via Matlab (R2007b). As Matlab Data Acquisition Toolbox dosen't support the access to the counter/timer of the 6259, I call 'DAQmxCreateCOPulseChanFreq' from the library. However, it returns a negative status indicating that the channel was not created. Can someone tell me why I have a negative status?
Miko
Here is the code:
% %load libraries nicaiu.dll,nidaqmx.h if not loaded
clc
if ~libisloaded('myni')
    disp('Matlab: Load nicaiu.dll')
    funclist = loadlibrary('nicaiu.dll', ...
        'C:\Program Files\National Instruments\NI-DAQ\DAQmx ANSI C Dev\include\nidaqmx.h', ...
        'alias', ...
        'myni' );
end
disp('Matlab: dll loaded')
disp('')
% Counter must be driven and read through 'c' function calls
% Define variable for taskhandle
taskh1 = uint32(1);
% Create task
[a,b,taskh1] = calllib('myni', 'DAQmxCreateTask', 'master', taskh1);
% Create channel name for counter input edge count
taskchans1 = ['Dev1/ctr0'];
%define required properties for pattern generation
DAQmx_Val_Hz = 10373; % a pre-scaled unit (aka DEFINE)
DAQmx_Val_Low = 10214; % resting state, pre-define unit
initialDelay = 0; % sec
freq = 16000; % Hz
dutyCycle = 0.5; % width / period. This ratio, combined with frequency, determines pulse width and intervals
% Create channel: specify duty cycle and frequency
nStatus = calllib('myni', 'DAQmxCreateCOPulseChanFreq',...
    uint32(taskh1), taskchans1, '', DAQmx_Val_Hz, DAQmx_Val_Low, initialDelay, freq, dutyCycle);
if nStatus == 0     % channel created successfully
    disp('Success')
elseif nStatus < 0  % error: channel not created
    disp('Error')
elseif nStatus > 0  % channel created with warning
    disp('Warning')
end
Miko
(7,655 Views)
Miko,
Unfortunately, I am not familiar enough with Matlab or have the tools to help troubleshoot your specific code.    I did find an example of a similar task performed in C.  The example is attached.
I hope this helps
-Pete
Peter C.
(7,639 Views)
Hi Peter,
The task is indeed the same but as I am not familiar with C, I can't see the little differences compared to my matlab code. It seems that I should change the Taskhandle name and type but I don't really understand how.
Anyway, I'll make some try.
Thanks for your help.
Miko
(7,637 Views)
Miko,
I found some general information on calling DAQmx functions in matlab.   You are using different hardware, but you may be able to use some parts of their code to help you.
http://forums.ni.com/t5/Multifunction-DAQ/Use-M-Series-cards-with-DAQmx-in-Matlab/td-p/185232
I hope this proves useful!
-Pete
Peter C.
(7,632 Views)
Thanks Peter!
It indeed proved useful, thanks to the last comment (slastuka p.10).
It seems that the input and output type depend on NIDAQmx version.
Here is the code (that works for me), in case help someone else:
clear all, close all
clc
        'alias', ...
        'myni');
end
% libfunctionsview('myni')
Taskh1 = [];
% Create task
[a,b,Taskh1] = calllib('myni', 'DAQmxCreateTask', 'Counter', Taskh1);
Taskh1 = libpointer('voidPtrPtr',Taskh1);
Taskchans1 = libpointer('cstring','Dev1/ctr0');%Counter name
NameChan = libpointer('cstring','');%Channel name
DAQmx_Val_Hz = int32(10373); % Units: Hz <-> 10373
DAQmx_Val_Low = int32(10214); % Resting state: Low <-> Terminal is at a low state at rest. Pulses move the terminal to a high state.
InitialDelay = 0; % Delay (sec) from the start call to the beginning of the pulse train ; this is currently set to 0.0 by default.
Freq = 16000; % Hz
DutyCycle = 0.5; % width / period. This ratio, combined with frequency, determines pulse width and intervals
    Taskh1, Taskchans1, NameChan, DAQmx_Val_Hz, DAQmx_Val_Low, InitialDelay, Freq, DutyCycle);
    disp('Success')
    disp('Error')
    disp('Warning')
end
 I don't know for the following, but at least I can create the channel.
Miko
(7,623 Views)
Great!
I'm glad it helped.
-Peter
Peter C.
(7,616 Views)
