12-02-2008 11:23 AM
I have a PCI-6602 and Labview 8.0. I need to create a complex wavefrom output and I don't know how to create this waveform with the 6602, I know that I can create this pulse format by using the Agilent Pulse Generator but I would like to use the National Instruments. If somebody has an idea about how many counters and the physical connections that I need, also about how can I use labview to generate a complex waveform output.
I've attached the waveform that I need to generate continously and I hope that I can use the PCI-6602 for this purpose.
12-03-2008 01:00 PM
This is a duplicate post, for the main post please see:
NI Discussion Forums: How to generate two diferent pulses and re-trigger such pulses continously
Dan King
