Counter/Timer
Generating Interrupts using the PCI-6036E
I will like my PCI 6036E to generate a hardware interrupt each time a pulse or logic 1 is read on one of the digital input channels. I need to compute velocity from the encoder pulses connected to digital channels 0 and 1.
Can this be done?
Thanks in advance.
Knji
(4,006 Views)
After browsing through the C Function manual, I found out a counter will do for my purposes. Basically, I want to use the counter available on the PCI-6036E to counter encoder pulses.
Does anyone have any pointers on how I go about doing this?
TIA
knji
(3,989 Views)
Knji,
Counters are definitely the means to accomplish your task. There are two 24-bit counters on the PCI-6036E. If you just want to count pulses, you will want to use a simple event counter example. There are also examples that measure frequency, period and pulse width. If you have the NI-DAQ driver installed these examples will be included with LabVIEW or LabWindows/CVI, and you can browse or search for them at Help>>Find Examples. If you want C/C++/VB examples, you can find them in the following directory:
C:\Program Files\National Instruments\NI-DAQ\Examples
Hope this info helps!
-Alan A.
(3,983 Views)
Thank you Alan.
Klaus
(3,978 Views)
