Counter/Timer
Generating a frequency ramp in ANSI-C (DAQmx, Status: -200459)
I'm trying to write a stepper driver output that ramps up in frequency.  I have it running with a fixed number of steps and a fixed frequency.  I'm just trying to ramp from 0Hz to some speed over a fixed period of time using the ANSI-C function DAQmxWriteCtrFreqScalar.  When I call it on a task (regardless of if it's running or not) it fails with the status response -20459:
Measurements: Write failed, because there are no output channels in this task to which data can be written.
Task Name: linMotorDrv
Status Code: -200459
Is there a way to change the frequency of a continuous pulse train while it's running?  And does anyone know why I wouldn't be able to write to this output channel?  I'm able to set all the parameters when configuring the task initially, but never again after.
Thanks in advance.
-mtburt
(4,855 Views)
Hi mtburt,
Welcome to the NI forums!
This thread covers the same issue (coded in LabVIEW).  Instead of calling DAQmx Write, I would suggest using the DAQmxSetCOPulseFreq and DAQmxSetCOPulseDutyCyc functions:
  • int32 __CFUNC DAQmxSetCOPulseFreq(TaskHandle taskHandle, const char channel[ ], float64 data);
  • int32 __CFUNC DAQmxSetCOPulseDutyCyc(TaskHandle taskHandle, const char channel[ ], float64 data);
This should allow you to change your pulse settings on the fly in software.  There is an open Corrective Action Request regarding the misleading error message--we hope to fix this soon to make things more clear.  Thanks for posting and have a great day!
-John
John Passiak
(4,843 Views)
