Counter/Timer
Generating pulse packets on PCIe6612 (or PCI6602)
I'm trying to generate a high frequency pulse train that turns off when my gating line is down. The attached VI does just that, but there is a drift between the high frequency line and the gating line.... (Note: there is no drift when the duty cycle of the gating line is set to 0.5)
Thanks!
Marc
(3,518 Views)
Not sure what you mean by "drift" exactly, but since both counters work off the same board and the same internal timebase, you're certainly in position to have consistent relative timing.
I only see two things to comment on, the former much more important than the latter.
- you have a curious combination of defining your gating pulse to be retriggerable, but also *not* to use a start trigger.  I'm not sure what should happen there, but I'd be inclined to expect a single untriggered pulse to occur as soon as you run it.
- you never clear the task that generates the gating pulse.  Auto-cleanup will take care of this when execution ends, but it'd be better to clear it explicitly.  Not likely to be a contributor to your issue though.
-Kevin P
(3,486 Views)
