Counter/Timer
Getting start with PXIE 6674T
I read the manual for PXIE6674T but I still have no clue on getting start with this module.
In my LABview, I cannot see any block for the PXIE6674T, but I do check the configuration on MAX that my PXIE6674 is there.
Can someone give me some example on this module? simply just need it to generate a 20MHz clock.
(2,896 Views)
Accepted by topic author cyanxss
The software support for the PXIe-6674T is in NI-Sync. The VIs are available on the function palette under Measurement I/O >> NI-Sync.
For examples, in the Example Finder (Help >> Find Examples), navigate to Hardware Input and Output >> Timing and Synchronization >> Signal-based. Sounds like maybe the "Generate DDS Clock and Route" example there would be helpful.
(2,814 Views)
