Counter/Timer
High accuracy duty cycle with DAQ-STC
I am trying to measure the duty cycle of a 4 kHz TTL pulse train with high accuracy. I can do this over one cycle but actually need to average over a number of cycles because there is noise. This doesn't seem possible with the stanard VI's? Can anyone help?
Gavin
(3,461 Views)
Gavin,
There is an example on our website that does buffered duty cycle measurement on DAQ-STC devices that should be helpful for you. From www.ni.com/support you can search under Option 3 through Example Code for +duty +cycle +stc to find it or follow this link: E Series Duty Cycle Example
Molly K.
Applications Engineering
Molly K.
Web Support & Operations Manager
(3,461 Views)
