Counter/Timer
How best to avoid ringing between preamp and counter input on AT-MIO-16?
I am trying to count pulses from a pre-amp using counter chips on the AT-MIO-16 but I am getting lots of ringing (150 MHz when I should get 1-10 Hz) even with a 50 Ohm terminator cap. Any suggestions?
(3,435 Views)
Match the impeadence of
the pre-amp out,
cable,
AT-MIO-16 input.
Prefect matching gives zero ringing.
Ben
(3,435 Views)
Hello;
This is looking like an impedance mismatch in between the DAQ device and the source of pulses device. When the impedance is not matching, a percentage of the waveform reflects back to the source, creating the ringging.
Hope this helps.
Filipe A.
(3,435 Views)
