Counter/Timer
How can I implement a Digital I/O counter with a maximum source frequency of 80 MHz (like 6602 board) using CompactRIO?
How can I implement a Digital I/O counter with a maximum source frequency of 80 MHz (like 6602 board) using CompactRIO? It appears as if the Digital I/O modules for CompactRIO are much slower than this.
Thank you,
--Ray
(5,763 Views)
Hi Ray,
The highest frequency input we offer for C Series modules is 20 MHz if you are doing LVTTL and 10 MHz for 5 V TTL.  These modules are the 9402 and 9401, respectively.  Unfortunately, there is no 80 MHz input on this form-factor.
Chris Elliott
x36772
(5,757 Views)
