Counter/Timer
How can I use a 6341 to provide a hardware clock to a program (ie 1 Second ).
I want to acquire a temperature reading from a 6341, at a 1 second rates.
(5,579 Views)
Hi as2001,
I would recommend starting out by taking a look at some of the analog input examples that come with LabVIEW. Open LabVIEW, go to Help>Find Examples. In the Example finder, go to Hardware Input and Output>DAQmx>Analog Measurements. In this folder you will find plently of examples on how to acquire data.
Leah
(5,573 Views)
