Counter/Timer
How can i synchronize Counter with NI-CAN
Hi, i am using the PCI 6259 and NI-CAN Card to do some measurements (Torque,rotation speed,CAN Botschaft) on a  motor. I've already connected two Cards with a RSTI Cable.
So far i can successfully synchronize AI, AO and CAN, however, there is one more counter that need to be  synchronized.
I've tried to simply give the same Sample Clock and Sampling rate to this counter(by using DAQmx Timing) from AI.
but the program doesn't work...
And I was trying to search the examples of Synchronisation between digital counter and CAN. I only can find the  examples of Synchronisation between AI and CAN... no more else.
So, is it possible to synchronize counter and CAN?
Message 1 of 1
(5,313 Views)
