Counter/Timer
How can the VI be modified?
Can someone help me with an example showing how to modify the VI attached? The aim is to get to change the frequencies on the fly but reading from an array. Each element (frequency) must run for 10 milliseconds before the next one is read and run also for 10 milliseconds and so on.
Please help
Chris
(4,024 Views)
Tiano,
Can you attach the VI in question? I don't see a link to it. Thanks.
(4,024 Views)
My apologies,the Vi is attached below.
This vi can be viewed in the NI site at the following link:
My apologies…the Vi is attached below.
Or This vi can be viewed in the NI site at the following link:
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3E21756A4E034080020E74861&p_node=DZ52328&p_submitted=N&p_rank=&p_answer=&p_source=External
Regards
Tiano
(4,024 Views)
Are you running into any errors when you implement your method? Or are you looking for programming help to get you started with your method?
(4,024 Views)
I'm looking for a programming help, or being more specific to improve the vi I've put together.
I'm getting a big delay (about 2ms) when there's change from a frequency spec to another. Is there a way I can get it done as fast as possible?
please take a look at the attached file.
(4,024 Views)
