Counter/Timer
How do I enable the counter debounce function on a USB-6229 device.
 I'm using LabVIEW 8.2.  Calling the property node CI.CountEdges.DigFltr.Enable generates an error that my hardware does not support this property.  The hardware documentation lists 4 debounce settings: 125 ns, 6.425 µs, 2.54 ms, and disable.  Using the example vi "Meas Dig Frequency-Low Freq 1 Ctr.vi" to measure the pulse rate of a flow meter operating between 5 and 300 Hz, I'm getting results that occasionally match the rate displayed on the oscilloscope but more often range between 30 kHz and 5 MHz.  The debounce filter seems like the perfect solution but I haven't been able to figure out how to enable or set it.
(4,661 Views)
If you are selecting "CI Pulse Freq", you are likely getting an error because that is not supported for the 6229.
You will likely get error -200431:
Possible reason(s):
Selected physical channel does not support the measurement type required by the virtual channel you are creating.
Create a channel of a measurement type that is supported by the physical channel, or select a physical channel that supports the measurement type.
Property: CI.MeasType
Requested Value: Pulse Frequency
Possible Values: Frequency, Period, Pulse Width, Semi Period, Two Edge Separation, Position:Angular Encoder, Position:Linear Encoder, Count Edges
Task Name: _unnamedTask
So, basically you can do debounce filtering and if you try something like 'CI Cnt Edges', since that is a task that is available for the 6229, but you will not be able to do the CI Pulse Freq even without the debounce filtering.
Hopefully that helps.
(4,641 Views)
Thanks Charles.  That certainly opens up the road for a new approach.  I'm a new user and I noticed with this first post that the system assigned an icon to my ID that looks like a T-bone steak.  Is this their way of identifying "fresh meat" on the site?
(4,635 Views)
you can go to my settings >> Avatars and change it there, haha, if you feel like you are being singled out
(4,612 Views)
