Counter/Timer
How do I get 12 hardware counter channels?
I am wanting to count 12 seperate pulse signals. The USB device I am currently using (6501) has only 1 counter channel that works great for one signal, but the extremely short pulses (@5us) makes software programming a nightmare for 12 signals into the digital inputs lines.
Ideally I would be able to find a dedicated 12 channel usb counter that I can read into labview, but it does not look like an option. It looks like I may have to go with a combination.
What are cost effective combinations of hardware devices with dedicated counters to supply my total of 12 channel counter needs?
(5,595 Views)
As always, "it depends."
What kind of counter measurements do you intend to do?  Occasional on-demand measurements or buffered measurements for transient analysis?
People's idea of cost-effective varies too.  On the forums, it often means that someone can't spend $1000 on truly suitable hardware, but they *can* spend many extra weeks cobbling together a sub-optimal solution with inadequate hardware.
3 PCI-express X-series devices would be a very efficient hardware platform for all manner of buffered counter measurements since you get 4 DMA channels per card and you don't share bus bandwidth among cards.
A single X-series device would let you capture 12 pulses as hardware-clocked digital input signals that you can post-process for pulse analysis.  You could even do neat things like capture based on change detection while using a counter to create timestamps from the change detection event pulse.  In short, it's very likely you can capture all the necessary data but will need to do some software post-processing that's conceptually straightforward but fairly tricky to get completely and exactly correct.
-Kevin P
(5,591 Views)
