Counter/Timer
How do I get the DAQ assistant counter to wait for 1st trigger pulse to begin counting?
I am attempting to build a counting VI to count pulses in an interval controlled by an external trigger.  I have the counter counting but my 1st two data points are random.  How do I get the counter daq to wait until it receives a trigger pulse before it begins adding counts to the buffer?  Right now I am feeding the DAQ square wave pulses at 100Hz and triggering the counter to output everytime it receives a trigger (10Hz square wave).
My outputed data looks like this:
3147
-120
30
30
30
30
I should be seing all 30s.
Below is a pic of my setup.  Thanks for your help!
(5,874 Views)
Hi Matt99eo,
Have you configured your device for triggering?  Although you have not mentioned your device specifically, the M series user manual provides a great explanation of digital triggering.  Using the DAQ Assistant, this can be configured from the triggering tab.  Hopefully this helps!
h_baker
(5,861 Views)
