Counter/Timer
How do I output a finite pulse train through multiple counters?
Hey sneeky.. Hey knight,
Did you people solved that problem ?
I have same task but I need to generate continous pulse train in all 8 channels..
can you help me ?
I have done as specified by you, but delay is not working.
Message 11 of 15
(2,296 Views)
My code,
 in this code all 8 output is available but, all starts with random delay added to delay I specified.
Message Edited by Hitesh Dhola on 08-11-2009 11:56 PM
Message 12 of 15
(2,295 Views)
another try,
In this code, I have taken first counter to trigger all others, all other things same....
New problem is all counters starts at same time even I specify the delay
Message 13 of 15
(2,292 Views)
Hello Hitesh,
You have a good start but there are a couple of things that need to be changed.  First, you need to ensure that the slave devices (those starting off the internal output of the first counter) are started prior to the master starting.   Also, if you simply want 8 continuous pulse trains started at the same time with different initial delays, you don't need to set a retriggerable start trigger.  I created a simple example to help you get started.  Please take a look at the community page here.  I've also attached a screenshot of the block diagram. Please let me know if you need any additional explanation or help.
Paul C.
Message 14 of 15
(2,272 Views)
Thanks... It's working
Message 15 of 15
(2,251 Views)
