Counter/Timer
How do I select the 80 Mhz internal source for the PCI-6602?
The user manual says the PCI-6602 counter/timer has
an internal 80Mhz as well as 20Mhz source. I'm trying
to select the 80Mhz source using the ni-daq function
GPCTR_Change_Parameter() in Visual C++, the header
file nidaqcns.h supports 20Mhz but not 80Mhz.
(4,775 Views)
Use ND_INTERNAL_MAX_TIMEBASE paramID to define the
source frequency in the GPCTR_Change_Parameter() function.
(4,770 Views)
Hello;
Try checking out the ND_INTERNAL_MAX_TIMEBASE. This will let you use the maximum time base your device supports
This is mentioned in the function help for GPCTR_Change_Parameter in the NI-DAQ function reference manual. You should have that installed on your machine if you have NI-DAQ installed.
Hope this helps
Filipe A.
(4,771 Views)
We have tried this solution and it still doesn't work ... Any other solutions or is this just a bug in NI-DAQ ?
(4,743 Views)
I've never heard of a bug with selecting the 80MHz timebase on the 6602. Can you post the code that isn't working for you and the error message that you are receiving?
gus....
(4,728 Views)
Hi, this is a simple program in C as requested that measures the time between two pulses (buffered).
I'm working with the PC-6602, and it doesn't work with an internal 80Mhz source.
The errormessage is "C:\Frederik\gecord\oscillator\bufferperiodtest.cpp(87) : error C2065: 'ND_INTERNAL_80_MHZ' : undeclared identifier
Error executing cl.exe." after compiling. When I use "ND_INTERNAL_MAX_TIMEBASE" it does work, but on 20 MHz, not on 80.
Does anyone know what i have to do?
(Ps: working together with "mtytgat")
(4,637 Views)
I've found the solution. You've got firts determ the application you want to use (for ex. ND_BUFFERED_PERIOD_MSR) and then the internal timebase (ND_INTERNAL_MAX_TIMEBASE). If you do it the other way around everything works normal, except that the "ND_INTERNAL_MAX_TIMEBASE" 20 MHz is and not 80 MHz.
The solution is simple, but it wasn't very obvious that this was the bug in my programs, because everything else worked normal.
greetz
(4,500 Views)
