Counter/Timer
How do I toggle output when input has been high for more than programmable time?
I am trying to generate a trigger signal whenever an input signal is high longer than x uS. I'm using a 6602 and I'm sure this will take more than one counter. The input signal has several short pulses and one pulse has a high time 5-7 times longer than the high time of the short pulses. I want to trigger x uS after the rising edge of the long pulse. I will program x to approx. 2-3x times the short pulse high time to prevent false triggers. How do I do this?
(3,339 Views)
You can configure that counter to do position measurement and setup its output to pulse when the coming pulse has a longer period than he one previously chosen.
I'm part of a team of experieced DAQ programmers that constantly deal with this difficult counter problems. We can write the code for you in case you need it.
You can contact me at ericbowie@excite.com.
Regards
Eric
(3,339 Views)
