Counter/Timer
How do i alter the timebase when using Measure Period (DAQ-STC).vi
Dear All
I am using the Measure Period VI in Labview 6 to get the period of an external signal. The VI works fine but the internal timebase used by default in the VI (20MHz) is too high a frequency (i am looking at periods of between 1 and 4 seconds).
I am using an E series board and from the help files i understand there is another internal timebase (100KHz) which alolows measurement of periods of up to 167 secs rather than 838ms with the 20Mhz timebase.
How do i select this timebase for the VI, there is even a note on the VI which says 'This calculation assumes max timebase is selected as the source'.
Please Help, i'm almost finished my VI apart from this!!
Regards Ro
ss
(3,598 Views)
Forget the above question, i ahve figured it out. If anyone else is interested you can use the Source specification to set the time base you use!
Ross
(3,598 Views)
