Counter/Timer
How to access counters in cDAQ9174 / NI9403 with C / Matlab
I read that the cDAQ9174 has four counters available. However, they need to be interfaced through some other Card and they're now directly available to the user. How do I do that with the NI9403 digital I/O card? How could I do that with LabVIEW but with C/Matlab?
Thank you
Jan
(4,763 Views)
Hello Odyseeus,
hope this helps
Count Pulses on a Digital Signal Using NI Devices
Create a Counter Input Channel
this do not work with the NI 9403, because there are not PFI line available. You need instead a module like the NI 9401.
best regards
Alexander
(4,750 Views)
Thank you Alexander for the reply. Sounds like I need to purchase a different NI card. How do i find out which cards have a PFI-line?
(4,743 Views)
Accepted by topic author Odysseus
Hello Odysseus,
normally all moduls with 8 or less DIO inputs.
C Series Signal Connections for Counters
best regards
Alexander
(4,740 Views)
