Counter/Timer
How to buy a PC to accomodate 5-Volt PCI card PCI-6602?
We've been having the devil of a time finding a computer with 3 or more PCI slots at all, and then most makers & sellers have no idea about voltage compatability!  My understanding is that the NI-PCI-6602 (of which we have just bought 2) is a 5-Volt card, and therefore my PC needs to have either a "5-Volt" slot or a "Universal" slot which would be capable of accomodating either a 5 volt or a 3 volt (3.3 volt?) card.  To confuse the issue further, some *cards* are said to be 'Universal,' meaning that they can operate in either a 5 volt slot or a 3 volt slot.  Thus, a slot capable of accomodating a 'Universal' card is not necessarily a "Universal" slot!  Oh, and did I mention that all these cards and slots fit mechanically, it is just that some combinations don't work electrically.  Besides this, I have heard that some motherboards, while not offering "Universal" slots are switchable to either 5 or 3 volts.  I'm not even getting in to the different kinds of PCI slots (PCIE, PCIX, etc.)  The slot I think I need for my new pair of 6602s is a plain old PCI slot.  I am happy to buy (or even build) new computers to do this job.  I just need something with 5-volt plain PCI slots, five of them ideally but at least three.  Thank you!
(5,610 Views)
Pretty much any new computer that you can get will have the appropiate PCI type that you need to use these boards. You will be looking for a Computer/Motherboard that is compatiable with the PCI 2.1 or 2.2 standard which supports the 5V you need to power these PCI-6602s. What you might be seeing is a lot of computers that are coming with the PCI-Express slots, which are very different then stardard PCI. These computers, since they have PCI-Express, have a limited number of standard PCI slots (usually 3). So if you go with a computer with no PCI-Express, then most will have 5 slots. So depending on whether you go with your favorite computer maker or decide to build a machine yourself just make sure that the motherboard says it has 5 PCI slots (and not PCI-Express, or PCI-X) and as long it is new you should be just fine. If you want to read up on some on the PCI standard here is a link to a good resource.
http://en.wikipedia.org/wiki/Pci
Good luck with your computer hunting.
-GDE
(5,581 Views)
Dear DrWin
Are u able to find out any PC of such Kind as I too has a similar requirement. Also, I could see that most of the PCs are now coming with PCI 2.2 standard which supports 3.3 signalling. My PCI slot require 5V power and signalling so I expect it not to work with PCI 2.2 slot. In general does PCI cards comaptible with 2.1 standard work with 2.2 PCI slot computers.
Thanks and Regards,
Siddu
(5,246 Views)
Hi Siddu,
The PCI 2.2 spec will output 5 volts if the card is a 2.1 standard card.  The main trouble will be PCI 2.2 cards being used on a 2.1 standard slot.  That will not work.
I don't know would meet your overall requirements, but the PCI2.1 card will work in the 2.2 slot.
Have a great day,
Michael D
(5,224 Views)
