Counter/Timer
How to control two USB 6501 simultaneously
I am trying to measure two signal by using two counters of different NI USB-6501 device. The problem is that they measure one after another so I loose half of the time. Can anyone please help me so that I can simultaneously measure them. I have attached the sub vi which I used in the main vi to control both USB-6501.
Thank you
Somnath
(5,429 Views)
Make that subVI reentrant.  Then you can have multiple calls of it that will run simultaneously.
(5,426 Views)
