Counter/Timer
How to count TTL pulse by DAQ through BNC 2090?
I'm trying to count the TTL pulse from a APD by DAQ. There are some very nice discussions about this issue in this board. However, I am a novice and not sure about the hardware connection. The signal from APD is delievered out through a BNC cable and I'm trying to deliever this signal to DAQ through BNC 2090. I tried just simply connect the BNC cable to ACH0 and tried running the vi's, such as "Count_Edges.vi" and "Count_Events.vi". But I got no counts. I noticed that both these vis are actually reading signal from PFI port. That could explain why I got not counts.
So now the problem is how should I connect my signal in a BNC cable to the DAQ and have the counting working? Thank you for your help.
(4,302 Views)
What model DAQ card is connected to the BNC2090? If it has counters on it, I would use those since that is the most straightforward approach. Then under LabVIEW Help, go to find examples and search on count. Look for a suitable example that mentions the DAQ card you have.
(4,300 Views)
Hi AnalogKid2DigitalMan,
Thanks for your reply. I'm using PCI-MIO-16XE-10 card. I'm a graduate student and this is my first time using DAQ technique. So would you please be more specific on how to connect the BNC cable from APD to PCI-MIO-16XE-10? Or do you know where can I find more information about that issue? Now I just simply connect the BNC to ACH0 port. Obviously, that shouldn't work.
Thanks again.
(4,290 Views)
Hi Opal,
Here is what you should do for the hardware connections with these devices:
- connect your external signal to the BNC-2090
- connect the 68 pin connector on the BNC-2090 to the 68 pin connector on your DAQ board. You should have a 68 to 68 pin cable for this.
That is all that is involved with the hardware connections. After this, you should be able to read your signal. Here is the link to a helpful DAQ manual with in depth getting started information: DAQ Getting Started Guide. I hope that you find this information helfpul.
Hal L.
(4,277 Views)
