Counter/Timer
How to generate an internal pulse train and use this to trigger voltage readings
I am using the PCI 6602 board and the NI-DAQ 9.5.1 driver.  I want to generate an internal pulse train of user specified frequency, and at the rising edge of the pulses, trigger a voltage reading from an external device (a 5V DC power supply).  I'm not sure if this is possible with the given card, but if it is, I have a few specific questions on how to get this application running.
1) How do I generate an internal pulse train (what physical wiring connections must be made and what C++ functions would be useful)?
2) How do I physically wire the power supply so the NI card can effectively read this voltage?
3) What C++ functions might be useful to have the rising edges of the pulse train trigger this voltage data acquisition?
Thank you in advance for the help.
Zach
(5,699 Views)
Hello Zach,
The PCI-6602 has 8 counters that you can use for that.
You can use the ‘DAQmxCfgSampClkTiming’ function to do that. Please take a look at the NI-DAQmx C reference Help to get further information about each NI-DAQmx C Functions.
Mr.O
(5,689 Views)
