Counter/Timer
How to reset counter with each iteration and how to introduce a delay
Hi everyone,
First I apologize for the basic level of my questions, I am very new with Labview...
I am reading counts off of a USB-6008 labview chip using the DAQ assistant and I write the output to a file. The problem is that instead of giving me the number of counts for each iteration it gives me the sum of it all. How do I make the DAQ assistant reset to 0 counts on every iteration? I tried using a shift register but it just adds a counter to my file and nothing else...
Thanks a lot
(7,232 Views)
Hi Peluche,
You can programatically reset to zero by saving what the count was at the last read and subtracting that amount off each time you read. I wrote an example VI that does this. The top shift register is just being used to model the counter.
I hope this helps.
TimC
(7,211 Views)
Hi Tim,
Thanks so much for your answer. Unfortunately the vi you sent me isnt compatible with my version of labview (2010). Could you make it compatible please?
Thanks again!
(7,206 Views)
Accepted by topic author Peluche
Sure thing. Sorry about that.
TimC
(7,187 Views)
Hi Tim,
I would like to thank you again for your code. I tested it then adapted it to my needs and it solved my problem.
Thanks again!!
(7,164 Views)
No problem Peluche.
I'm really glad I could help.
TimC
(7,145 Views)
