Counter/Timer
How to retrieve counter value w/ 6036E card?
I'm trying to get the value of the event count through counter 1 of a 6036E card, so I wired my signal to PFI3/GPCTR1_SOURCE and DGND. I couldn't get any response w/ LabVIEW (well, in fact I get "0" where I should get sth). So I tested w/ Measurement & Automation and found that the count value was shown on both PFI2/CONVERT and PFI4/GPCTR1_GATE (it doesn't matter if I choose Counter0 or Counter1 to be read).
Is it normal? If so, how can read this value w/ a VI?
Thx for your help,
Nicolas
(3,566 Views)
Hi nicolas,
Your signal must be connected to the source of your counter if you want to count the events.
Does it works with WAX or not ?
With LabVIEW have you tried the exampel entlited "Count digital event.VI" Go to Help >> Find examples . Select Hardware I/O >> DAQmx  >> counter .
Regards
Alexandre D
(3,559 Views)
Sorry for being so late but I couldn't post anything until now.
Thank you for your answer. I didn't modify the right example Smiley Sad and now it's working just fine (but I still don't understand why I get the value at the Gate pin???).
Nicolas
(3,524 Views)
