09-15-2009 10:24 AM - edited 09-15-2009 10:25 AM
I posted a question on the Multifunction DAQ by mistake, when it should have really been here, on the Countes/Timers board. I guess I am still hopeful that there is a way to do what I am trying to achieve.
I would really like to see if anyone has any other opinions and/or possible solutions to my problem. The link to my original post is below.
Thanks in advance for anyone who wants to give it a/another try 🙂
http://forums.ni.com/ni/board/message?board.id=250&message.id=51882#M51882
Solved! Go to Solution.
09-17-2009 09:42 AM
09-17-2009 02:29 PM
Hi Doug,
I thought that there may be a way of getting around this problem by setting the tristate property to flase, but I take it that this can only be done for the counter's output to a PFI line, and not the gate (or source) right?
09-18-2009 08:27 AM
09-18-2009 10:08 AM
Aaahhhh!
Ok. Well, thanks for setting the facts (and me) straight
So the next idea was to have both of the counters and the DI line that will be receiving the trigger run off of the same "Sample Clock", i.e. ai/SampleClock. First prepare both of the counters, then prepare the DI line, and then start all of them at the same time. This would all be done well before the expected trigger would come in, so that all of these channels would already be collecting data simultaneousely well ahead of the trigger. In this way, I can correlate the time that the trigger is received in the DI channel with the time in the counter channels. Is this what you were referring to as artificially arming the counters?
09-18-2009 01:19 PM
I forgot to add a couple of more question to my previous post:
09-21-2009 03:42 PM
