Counter/Timer
How to turn on Pad Synchronization with 6602 Card?
Does any one know where some example C++ code can be found to turn the Pad Synchronization feature of the 6602 Counter/Timer card ON. The 6602 default state is supposed to be Pad Synchronization = disabled according to the reference in the function help file (only reference) on this topic. The feature is described in the 6601/6602 users manual in detail but the users manual itself does not show how to access the feature. I have searched all of the DAQ 6.9.2 function reference help file but there is no reference to the word "PAD". Thanks...
(3,223 Views)
Hello;
To enable pad synchronization use the DAQ function call Line_Change_Attribute function or the Line Set Attribute VI in LabVIEW.
Hope this helps.
Filipe A.
(3,223 Views)
