Counter/Timer
How to use COChannel Count property in DAQmx .NET to get the total number of pulses in a continuous pulse train?
I'm studying the GenDigPulseTrain_Continuous example from the NI DOTNET3.5 examples.  I'm trying to use the COChannel Count property to get the total number of pulses generated.
A code snippet from the example with minor modifications for my hardware is shown below:
try
                myTask = new Task();
                _startCount = 0;
                myTask.COChannels.CreatePulseChannelFrequency(counterComboBox.Text,
                    "ContinuousPulseTrain", COPulseFrequencyUnits.Hertz, idleState, 0.0,
                    Convert.ToDouble(frequencyTextBox.Text),
                    Convert.ToDouble(dutyCycleTextBox.Text));
               COChannel d = myTask.COChannels[0];
               d.PulseTerminal = "/DAQ/PFI4";  //added this for my hardware wiring
                myTask.Timing.ConfigureImplicit(SampleQuantityMode.ContinuousSamples, 1000);
                myTask.Start();
                _startCount = myTask.COChannels[0].Count;
                startButton.Enabled = false;
                stopButton.Enabled = true;
                statusCheckTimer.Enabled = true;
I'm setting myTask.COChannels[0].Count to _startCount, but the value does not seem to correspond to the actual number of pulses.  It produces a huge number.  The NI DAQmx help files regarding the class just says the Count "Indicates the current value of the count register".
How can I use the Count property to return the total number of pulses generated once the user hits the Stop button?
-Chuck
(5,862 Views)
Unfortunately, the short answer is, "you can't."   As you've seen, the count register is busy managing the pulse timing
characteristics and isn't available to count the # of pulses generated.  The best alternative is to program a 2nd counter
to count the pulses generated by the 1st.
-Kevin P
(5,855 Views)
Interesting.  I wonder why DAQmx exposes the Count property of the counter if one cannot use it to check the count?  I was expecting there to be some type of tick conversion to make the value returned useful.
-Chuck
(5,847 Views)
