Counter/Timer
How to use the USER lines on the BNC 2121 with the 6602?
Hi There,
The 6602 has 8 counters on it, I want to use all 8. I have the BNC 2121 accessory which allows me to plug BNC cables into the card. There's 2 main groups of 4 lines for 2 of the counters (PFI 32-39) and then 6 USER lines. I'm using the DAQmx Channel -> CI.CountEdges.Term property node and a DAQmx Physical Channel to configure the input for each counter. I've tried expanding the IO Name Filtering on the DAQmx Physical Channel to include as many things as possible, but I don't see these 6 user lines listed anywhere. Anyone know how I can use them?
Chris
(3,265 Views)
Hello Chris,
The user lines are to create your own inputs and outputs by wiring the corresponding spring terminals together.  For example, to make User 1 be the source for counter 2, wire the spring terminal "SRC2" to "USER1".  Then in the DAQmx Physical Channel constant, choose counter 2 for your count edges operation and connect your signal to USER1.
I hope this helps!
Laura
(3,255 Views)
