Counter/Timer
How to visualise continues Data aquisition from a PCI 6602 with 2121 BNC connector board in C++ ?
Hello everyone,
We are trying to get on the screen the aquired pulses from our  PCI 6602 with a 2121 BNC connector board, from several devices. We are able to read the data and save without problem, but we cannot look at it while we are measuring. Anybody has an idea to how program this in C++ ? Any suggestion is welcome!
Thanks for the help
(5,726 Views)
try to look for some example programs and Tutorials:
Examples Results
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:ex/q/DAQmx%20C%2B%2B/...
Tutorials Results
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:tu/q/DAQmx%20C%2B%2B/...
You should also have a look at the "C Reference Help" which is installed with the NI DAQmx driver.
Acquire N Scans (Visual C++ 6.0, CW++, NI-DAQ)
http://zone.ni.com/devzone/cda/epd/p/id/207
Continuous Analog Acquisition with Producer Consumer Architecture in C#
https://decibel.ni.com/content/docs/DOC-4253
Good Luck!
Matteo
(5,663 Views)
