Counter/Timer
I am trying to use both DaqMx and DaqMxBase on the same (Windows) PC
Context: I am seeking to build and test the EPICS driver for "National Instruments - Various DAQ cards" - see http://www.aps.anl.gov/epics/modules/manufacturer.php for Windows.
This depends on NiDaqMxBase because it is built for Linux.
Consequently, I have installed DaqMxBase 3.7 on my (Window 7 /x64) PC, which already held DaqMx 9.7.5.
I cannot get DaqMxBase to recognise my pci-6601 counter/timer card.
It it recognised by DaqMx.
Should this card be recognised by DaqMxBase on Windows?
Is it OK to have both driver versions installed on the same PC?
(6,417 Views)
Hey pheest,
I'm afraid the answer is no, the PCI-6601 just isn't compatible with Daqmxbase.
Reference. http://www.ni.com/white-paper/6910/en
Justin, Applications Engineer
(6,379 Views)
Hi Justin,
If I understand the document correctly, the card is supported on Linux by DaqMx, is that correct?
More generally, as far as I can see, there aren't any devices that are DaqMxBase-supported on Linux, that are not also DaqMx-supported.
So the only reason to stick with DaqMxBase would be for OS X support of some devices.
(6,374 Views)
Hey pheest,
You are correct! Just to clarify though;
In regards to PCI 6601 compatibility,
Windows 7: 9.5.1mx
Linux: 8.0.2mx
OS X: Not supported
As you suggested, in general, the only reason left to use DaqmxBase is if you are using OS X.
(6,370 Views)
Hi Justin,
Can I ask about USB-6008 (which doesn't show up in the document, presumably because it's newer)?
Peter.
(6,368 Views)
Hey Peter,
The USB-6008/9 has it's own article on this that I will link rather than typing it, it shows which operating systems support which drivers. Base and mx are both supported in some instances.
http://digital.ni.com/public.nsf/allkb/2B1BB86D649297FB86256F96007AC55E
Interestingly, in this case, Linux seems to only be supported by the Base driver.
(6,366 Views)
Thank you, Justin.
Perhaps I will need to provide some kind of dual solution.
That would be a bit irritating.
Cheers,
Peter.
(6,364 Views)
