Counter/Timer
I do not see the DAQ Assistant Express on Functions>>Input palette.
Software config: Windows XP machine, Traditional NI-DAQ 7.4.4 for PCI 6602. I do not see the DAQ Assistant express on Functions>>Input palette. I get error message when I place the Instrument I/O assistant on the block diagram:-" Measurement and Automation Explorer or Instrument I/O Assistant not installed correctly. Please install from LabVIEW CD". I've tried uninstalling, re-installing driver and rebooting my computer several times.
(3,622 Views)
Hello PJ-SJM,
The DAQ Assistant Express VI installs with the NI-DAQmx Driver and not Traditional NI-DAQ.  The good news is that the PCI-6602 is supported in both Traditional NI-DAQ and NI-DAQmx.  Check this KnowlegeBase article to find out what version of NI-DAQmx you need and then search the Drivers and Updates page for to find the version you need.  Once you download and install the driver you should see the DAQ Assistant Express VI on your functions pallet.
The Instrument I/O Assistant is not for use with DAQ cards, it is for using other communication protocol like serial or GPIB.  However, if you need this you can install the Device Driver CD and it should work after that.  Note:  The device driver CD that came with LabVIEW should also contain the correct version of NI-DAQmx.
I hope this helps, and have a great Friday!
Brooks
(3,609 Views)
