Counter/Timer
I have bought a Multifunction DAQ card 6024E, can I use it as a counter for photon counting ?
I have a multifunction DAQ card. It says counters : 2, 24 bits in the specification sheet of the manual.
I want to do photon counting. The output form a PMT has to be measured, it is a hamamatsu H7421 -50 series photon counting head.
The out put pulse is a TTL pulse.
Can I do it ?
How to know the maximum speed of this counter ?
Please help
(4,111 Views)
Few more details: My card is a 200 KS/s card.
the output of the PMT has the following specifications:
Pulse pair resolution 70 ns
Pulse width 30 ns
I calculated the frequency then to be 14.28 MHz
since mine would be .2 MHz , I can't use it . Is my caclulation correct ? Does it mean I atleast need a card which has more than 14.28 MS/s ?
Please calrify.
(4,111 Views)
The news is much better than you fear.  The TTL pulses produced by your device are best measured by your DAQ board's counter(s), which are spec'ed up to 20 MHz for input (source) pulses.  Looks like you should be ok.  (Note: the 200 kHz spec refers to the maximum analog input sampling rate, and isn't likely relevant to your app.)
What you'll probably need to do is configure one counter for either buffered edge counting or period measurement with your device pulses wired in as "timebase source" signals.  These will cause the internal count to increment.  Your other counter will need to generate a continuous pulse train that will act as a sampling clock.  This will cause count values to be buffered in memory at a precise rate.
Search these forums for terms like "photon" -- the topic has come up numerous times and there's quite a bit of helpful info to be found.
-Kevin P.
(4,097 Views)
Satya,
From the datasheet for the device (page 8):
Maximum source frequency
Up/down counter/timers ........................... 20 MHz
Minimum source pulse duration ...................... 10 ns, edge-detect mode
So, as previous poster said, you should be fine.
Michael P
(4,095 Views)
Thanks to both of you. I understand the point. I will go through the rest of the literature in the site and cear other issues, I will write again if I have doubts. Thanks once again.
Message Edited by Satya the truth on 02-03-2006 11:32 PM
(4,092 Views)
