Counter/Timer
Implementing a counter
Hello All,
I am still new in Labview and the attached is my first ever project when using LabVIEW. Basically, as a summary, this program is capturing data from a Tektronix MSO 3000 series oscilloscope. I am using the rise and fall edges of this particular graph and will give me a pass or fail. Now I need to add a counter since this has to be repeated 24 times after giving me a pass or fail when measuring. How can this be done?  Also, can I reduce the downtime sine from the time it captures the measurement from the oscilloscope till it converts and give me the results the whole procedure is taking approximately 5 to 6 seconds?
Basically, I need help with the timer and this should increment after giving me a pass or fail
Downtime for the program
Thanks in advance
(1,795 Views)
Heya, I recommend you to check this similar feed:
https://forums.ni.com/t5/LabVIEW/Simple-Counter/td-p/3335513
(1,667 Views)
